Machine Vision
Read multiple camera gige Basler on 1 port lan have trouble
I am reading 4 Balser aca 2500 14gm cameras with the parameters as shown below.
I have read the camera but it has some problems when I grab the image. It appeared black lines on the image, like it lost data transmission, I also split the bandwidth of 4 cameras evenly. I don't know if anyone has this situation like me, can help me give some advice to fix it.
Thank all.
(1,324 Views)
This behaviour means you are losing packets. You can check this by monitoring packet related status information :
When you say you split the bandwidth, how did you proceed ? Because if you just decreased frame rate, that will not be enough  as the peak data rate is not changed.
I would recommend :
Sami
(1,296 Views)
Yes. The way I split the bandwidth is, as you said above, I split the DesiredPeakbandwidth from 1000 to 250 for 4 cameras. Packet size per camera I also set is 1500. My frame rate is currently 5fps. I think it's enough to work but it still suffers from the same problem on my post.
Can you give me another advice on this?
Thank you very much !
(1,291 Views)
I would strongly suggest you enable jumbo frames to use much bigger packet size (8 or 9k). If your ethernet adapter does not have such a feature, change to another one and also reduce the desiredpeakbandwidth to lower value (150, 200 ?).
Sami
(1,279 Views)
