04-07-2011 05:46 AM
Hello.
I want to receive "GVSP_PIX_BAYGR10_PACKED" format image by using NI-IMAQdx.
But NI-IMAQdx displays an error message.
NI-IMAQdx can receive "GVSP_PIX_BAYGR10_PACKED" Format?
04-07-2011 01:24 PM
Currently packed bayer formats (as opposed to unpacked) are _not_ supported natively by IMAQdx.
Eric
04-07-2011 07:54 PM
Thank you.
I think, "Packed Format" is very efficient method.
It's an unexpected result.
04-07-2011 11:23 PM
Hi hkgige,
Currently Vision only supports decoding bayer images to RGB32, not RGB64, so there is not much advantage to sending bayer formats >8bit. We do support unpacked 10 and 12 bit bayer formats but the result is still only 8-bits per color plane (RGB32). Every camera that has supported 10 and 12-bit packed bayer formats I have seen has supported 8-bits as well, so there was not much lost by not supporting the 10/12-bit packed modes.
We do have an open request to add higher bit-depth bayer decoding (to RGB64) which does necessitate the packed bayer formats to achieve the best efficiency, so it is likely we might support these at some point.
Eric
04-07-2011 11:47 PM
Thank you for your quick reply.
