Machine Vision
VISION BUILDER FOR AUTOMATED INSPECTION
I'm doing a program for a vision machine with NI Vision Builder and i want to know how l could make the counter of #Pass and #Fail in the interface of inspection work automatically ?
Message 1 of 15
(5,413 Views)
Hello nouva,
Not sure if I understood your question. The inspection interface shows by default the number of Passes and Fails when you run it continuously.
Would you please add more details on what you want to accomplish?
AGJ
Message 2 of 15
(5,383 Views)
send your file I try to fix it
Message 3 of 15
(5,345 Views)
For Vision Builder AI to count the number of pass/fail, you must insert a Set Inspection Status step in your inspection.
Hope this helps,
-Christophe
Message 4 of 15
(5,317 Views)
Thanks for your attention.
I have another problem : i try to generet labview code from the code that i have develop with Vision Builder 2013  but it asks me to install Labview and vision development module  2012 or later although i have installed the 2 of them it doesn't work .
I would ask you if there is a solution for this problem ?
Message 5 of 15
(5,301 Views)
Message 6 of 15
(5,296 Views)
Message 7 of 15
(5,295 Views)
Message 8 of 15
(5,294 Views)
Nouva,
Could you please add screenshots of NI MAX showing the versions that you have installed for Vision Builder, LabVIEW, and Vision Development Module?
AGJ
Message 9 of 15
(5,275 Views)
Hi ,
you will find 3 screenshots of the labview,Vision Builder and vision devlopment.
thanks
Message 10 of 15
(5,217 Views)
