Machine Vision
Vision Builder 2010 Active time not working when calling Vision inspection from testand 2010
I have an issue where I am timing a flashing light using the active time variable, when I run the inspection from the inspection view everything works, however when I run it from the configuration view or by calling it through teststand 2010 with the Vision Vi's the Active Time never changes from 0.00000.
I do not need precides timings so I am NOT worried about the +/- 20ms from the windows system clock.
(2,774 Views)
Hi Ryan,
Can you read any of the other variables using the Get Inspection statistics VI?  Is it only the Active Timer that doesn't change?
Cole R.
Software Engineer
(2,762 Views)
