Machine Vision
Where can I find the property "Vertical Mirror"?
Hello
I do have an USB camera connected which shows the image in the wrong rotation. Under Max there is a parameter in "Acquisition Attributes" -> "Vertical Mirror" which can be set to True.
How can I set this parameter under LabView? I can not find it under the properties.
thanks in advance
(3,585 Views)
I don't think you can set it as an acquisition paramter in LabVIEW, but you can flip the image once it's been acquired (use the IMAQ Symmetry.vi function in Vision & Motion > Vision Utilities > Image Manipulation palette)
Hope this helps
Epictetus
Antoine Chalons
(3,584 Views)
Accepted by topic author Norick_17
  In IMAQdx, you usually refer to properties by specifying them by string. See Programmatically Get and Set Attributes with IMAQdx
To get a list of supported attributes of your camera, call "IMAQdx Enumerate Attributes".
(3,578 Views)
this was exactly what I was looking for!
Thanks for the help..!!
(3,573 Views)
Nice to hear this.
You are welcome.
(3,570 Views)
