Machine Vision
can winddraw make user run-time shortcut menu?
Hi, I am wondering whether winddraw (machine vision, vision utility vi) can make run-time shortcut menu.
Generally, Image window has option(right mouse click) - advanced->run-time shortcut menu which is editable by user.
But when I click the popup window generated by winddraw vi, I can not see any option like image window(indicator)
Please help this issue.
Thanks in advance.
(3,747 Views)
Windraw is not used for this purpose.  If you need any kind of custom menu, you need to use the Menu Editor.
There may be some third party toolkits that can accomplish what you are asking, but I am not aware of any at this time.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(3,724 Views)
