Machine Vision
combining simple calibration VI to get camera calibration parameters
I am trying to get camera parameters from Camera calibration template. I have implemented calibration technique using distortion model in Vision Assistant and could obtain less error. Now, I would like to implement the same in a blank VI using different blocks. I am reading a circular grid image and sending it to IMAQ simple calibration which would return me a calibration template. By using this template I am trying to get camera parameters such as focal length, projection matrix etc. When I run the VI i am getting "True" at the Insufficient Data of internal parameters. I am not sure about the reason for that. Could some one let me know what is missing?
All I want to implement is to read a grid image and get a calibration template, using that template I would like to get camera external and internal parameters.
I am attaching the VI I implemented.
Thanks in advance.
(4,191 Views)
your dots is not clear or enough for this  vi test to see if all of dots are recognizable for this vi or not
(4,182 Views)
Do I have to perform thresholding, so that I can only send the image with those dots only. I tried doing that but still the I get "true" at Insufficient Data.
(4,180 Views)
yes test with calibration training to find best threshold
(4,175 Views)
I have another doubt, related to calibration. I am trying to find IMAQ learn calibration template VI but I couldn't find in the functions palette I have. I am using LabView 2014, could you let me know if there is a way that I can download specific VI and attach them to function palette. Thanks.
(4,143 Views)
(4,133 Views)
