Machine Vision
sometimes Configure.vi from IMAQdx is showing error
I am using the IMAQdx blocks to capture images and store them to the harddisk,
Sometimes when i run the VI , it shows the error in "configure.vi".
but when i restart my computer and run the VI again ,
It wil work fine.
I am unable to find the root cause for the error
Can someone help me in removing this error  ?
Please find the Attached VI and the error it is displaying.
Thank you
Thanks and Regards
Gaurav Pal
(2,805 Views)
Accepted by topic author Gaurav_Pal
I have not yet encountered an error so far in your code, however, I believe that the errors could be for the following reason:
1. The temporary memory allocation by IMAQ create vi needs to be cleared using IMAQ dispose, which also happens automatically when you reboot the system.
2 . The user configuration attributes may be out of range and thus they need to be reconfigured, which happens when you reboot the system..
(2,796 Views)
