Measure
Pressure measurement
I am new to LabVIEW and NI instruments. I am working on building an experimental setup. I need to perform pressure and temperature measurements.
I was able to do temperature measurement using thermocouples as sensor, NI9213 module (cDAQ-9174). I am not clear on how to do pressure measurement.
The pressure sensor is an Omega thin-film Pressure transducer (Link below)
https://assets.omega.com/pdf/test-and-measurement-equipment/pressure/pressure-transducers/PX1005.pd...
I have the NI9205 module. I am not sure if I can do measurement using this or I need to use a different module.
Please suggest
Kevin512
(4,160 Views)
Accepted by topic author kevin512
Hello
I reccommned to use something similar like  NI-9236C Series Strain/Bridge Input Module.
The output of the pressure sensors are very low and they required a bidge to be measured accurately.
Read this limk, may help to take better decision
https://www.ni.com/en-us/innovations/white-papers/06/how-to-measure-pressure-with-pressure-sensors.h...
(4,037 Views)
Thank you for the suggestion.
I had been able to figure out the measurement with the suggestion
Kevin
(3,901 Views)
