Analog Waveform Read on Digital Trigger
I have a NI PCIe-6320. I'm trying to set up a simple digital trigger for an analog input task. I've realised that StartTrigger.ConfigureDigitalEdgeTrigger takes a terminal rather than a channel name as the source. So I am configuring the trigger with StartTrigger.ConfigureDigitalEdgeTrigger("/Dev1/PFI0", Rising). I am trying to then programmatically fire the trigger with a DO write to p1.0. This doesn't seem to be working - I only enter my callback function after the read timeout of 10 seconds, and then cannot collect the waveform.
If I use StartTrigger.ConfigureDigitalTrigger("Dev1/port1/line0", Rising) and write true to p1.0 I enter the callback function, but then EndReadWaveform fails because the source terminal is invalid.
What am I doing wrong? I've been through the C# examples several times but none of them actually try to fire the triggers.
Message 1 of 1
(1,005 Views)
