How do I add Items to a Legend in WPF
I have added a Grpah with three plots. Added a Legend and wanted to have 3 plots of the graph as the Items to my Legend. Is there any way I can add the Legend items at design time?
<ni:Graph>
<ni:Graph.Plots>
<ni.Plot x:name="x1"/>
<ni.Plot x:name="x2"/>
<ni.Plot x:name="x3"/>
</ni.Graph.Plots>
</ni:Graph>
<ni:Legend items{???} />
Seems Items is read only collection....
(6,252 Views)
Accepted by BabaGoud
You can use the ItemsSource property to populate the Legend. You can show all items by using the graph itself, or you can limit it to a specific collection, as in this XAML from the Standard\DefaultPlotRenderers example installed with Measurement Studio:
<ni:Legend ItemsSource="{Binding AllPlots, ElementName=graph}"
           ItemBackground="{Binding Background, ElementName=graph}"
           BorderBrush="{Binding BorderBrush, ElementName=graph}"
           IsTabStop="False" />
~ Paul H
(6,212 Views)
Hi Paul,
I have 2 graphs on the window. the first graph has only one plot and the second graph has 3 plots.
My Legend needs to contain one item as a source from the first graph and only 2 of the plots as two more items from the second graph. Is there a way to mention plots from 2 different graphs as Itemsource of the Legend?
(6,188 Views)
Because of the amount of filtering involved, I think the simplest approach would be to initialize a collection in code-behind to contain the specific plots you were interested in. (If you had wanted to combine all items from multiple collections, then a WPF CompositeCollection could work as a purely declarative solution.)
The Legend will try to display the items from any collection you provide to ItemsSource, so based on your description:
XAML:
<ni:Graph x:Name="graph1">
    <ni:Graph.Plots>
        <ni:Plot Label="Graph 1, Plot 1" />
    </ni:Graph.Plots>
</ni:Graph>
<ni:Graph x:Name="graph2">
    <ni:Graph.Plots>
        <ni:Plot Label="Graph 2, Plot 1" />
        <ni:Plot Label="Graph 2, Plot 2" />
        <ni:Plot Label="Graph 2, Plot 3" />
    </ni:Graph.Plots>
</ni:Graph>
<ni:Legend x:Name="legend" />
Code:
var plots = new List<Plot>( );
plots.Add( graph1.Plots[0] );
plots.AddRange( graph2.Plots.Take( 2 ) );
legend.ItemsSource = plots;
~ Paul H
(6,181 Views)
Hi Paul,
I have an application where I have to plot data based on user selection and show them in a legend. So I have to create plots dynamically and add plot labels from a ViewModel
Then I have binded Legend to these plots and got the labels displayed on legend.
 The problem is - clicking on the legend items no longer change the visibility of the plots.
 Can you please help?
(4,382 Views)
[I see you posted a new question, so I have moved my answer there]
~ Paul H
(4,354 Views)
This sounds like how you would customize the legend in Windows Forms, not WPF?
~ Paul H
(3,314 Views)
