WPF/MS - Set Cursor Position with only X value
I've a WPF Cursor in a WPF Graph.
I would like to set the cursor X position at a value but it requests both X, Y value.
Is there a way to set the cursor with only the X position ?
ps : is possible, I would like not to have to compute the Y position. 🙂
(308 Views)
If you are only interested in controlling the X value, you might consider switching to MultiPlotCursor: it will use the host graph's horizontal axis by, allowing you to set the AxisValue property directly to your target X value, and the Values property will report all intersecting plot data values. To limit this to a single plot like Cursor, you can configure the AllowablePlots property accordingly. If you are trying to traverse plot values in sequence, the multi-plot cursor also has MoveNext/MovePrevious methods, without needing to calculate the "next X" value yourself.
If Cursor is a better fit for your scenario, you can use the SetDataPosition method and specify it to search only in the horizontal direction when finding the closest plot value:
var x = ...; // your target X value
var y = this.cursor.Value[1]; // existing Y value
this.cursor.SetDataPosition(new[] { x, y }, SearchDimensions.Horizontal);
~ Paul H
(284 Views)
