Now I'm using NI PCIe-6251 and BNC-2110.
I generated a stair-step signal and output it from analog output port AO1.
I want to make counter pulse signal which sync with the each step of the stair-step signal and output it from P2.4 port.
How can I generate such counter pulse signal and sync them by C# programming?
I want to know which class or function can be available to do this.
Thank you.
