Measurement Studio for VC++
Comment configurer et lire d'un capteur depuis un module analogique cFP-AI-111 avec Mesurement Studio for C++ ?
Le titre décrit mon soucis 🙂
Merci d'avance !
(6,116 Views)
Translation from french
How to configure and read a sensor from an analog module cFP-AI-111 with Measurement Studio for C + +
(6,103 Views)
Okay 😕
Well, i have an cFP AI  111 Analog, and i need to read a 16 analog channel, cool !
So, for that, i'm using Measurment Studio, VC++, and Measurement & Automation (MAX).
Before, with LabView, i was generating a File.iak, so i can configurate the Measurement & Automation (MAX) using that file to insert the Analog materiel for exemple.. Now, i don't wanna use LabView, but only Measerement Studio on VC++. So the questions is :
1- How can i configurate the Analog AI-111 for exemple ? (no LabView here hein ?!)
2- After configuration, how can i read form Channel X, and choosing the thype of data (float, int, ...) ? An exemple here will be really helpfull !
Thank you people !
(6,098 Views)
