Measurement Studio for VC++
Infinite and CNiNumEdit control
Hi everyone.
I need to use a CNiNumEdit control to assign or to show a double variable.
The variable can be any number, also infinite.
The control works well in showing any number but it is impossible to show the +infinite or -infinite value.
Doing so the control throws an exception.
I can use the TRY, CATCH_ALL macro but doing so it is impossible to set the text "infinite", or something similar, in the control.
How can I assign the infinite value to the CNiNumEdit control ?
Thanks in advance for your answer.
(4,034 Views)
Look at this KB online to see if it helps
AlessioD
(4,028 Views)
Ok thanks.
If it were possible to directly assign an infinite value to the control it would be better, however this is a good workaround.
If you know a direct way to assign +inf or -inf to the control let me know.
Thank you
(4,012 Views)
