Measurement Studio for VC++
get Voltage from NI ELWIS without LabView
Hi to everyone.
I need to write a program on C++, in C++ Builder. This program must to get voltage from NI ELWIS (https://www.ni.com/en-us/support/model.ni-elvis-ii.html). How can I do this?
In LabVIEW there is a special component. Does exist a .dll file, using it I can get voltage?
Or it's impossible and I need to access direct the device using  libusb and read data from USB port and then try to decode it?
I have never before used LabVIEW or ELWIS.
(5,645 Views)
Here is an article that will be helpful getting you starting writing a text based program using DAQmx with your ELVIS board:
https://www.ni.com/en/support/documentation/supplemental/21/using-ni-daqmx-in-text-based-programming...
Also, this article helps explain where the DLL's for DAQmx can be found:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8lkSAC&l=en-US
Thanks!
Stephanie S.
Application Engineer
(5,626 Views)
Thank you, let's see...
(5,619 Views)
