Measurement Studio for VC++
problem of simple counting task with c++
I got one NI device, the model is 6259. The device is useful and reliable. Task created in NI MAX accquired data successfully.
I learnt from a demo in "C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Counter\Count Digital Events\Cnt Dig Events\CntDigEv.c".
After confoguring the device("Dev1/ctr1"), channel("PFI12") and clock source("100kHzTimebase"), no error occured when compiling, while no data was accquired by running the task.
Could anyone help me to figure out what the problem is ?
Below shows the code i use. The source file is also attached.
#include <stdio.h>
#include "NIDAQmx.h"
int re;
TaskHandle taskHandle;
uInt32 data[1000000];
int main(void)
       taskHandle = 0;
       // DAQmx Configure Code
       re = DAQmxCreateTask("", &taskHandle);
       if (re == 0) printf("task created!\r\n");
       else printf("task create failed!error code:%u\r\n",re);
       re = DAQmxCreateCICountEdgesChan(taskHandle, "Dev1/ctr1", "PFI12", DAQmx_Val_Rising, 0,  DAQmx_Val_CountUp); //PFI12
       if (re == 0) printf("count channel selected!\r\n");
       else printf("count channel failed!error code:%d\r\n", re);
       re = DAQmxCfgSampClkTiming(taskHandle, "100kHzTimebase ", 100000.0, DAQmx_Val_Rising,  DAQmx_Val_FiniteSamps, 1000000);
       if (re == 0) printf("clock sed!\r\n");
       else printf("clock setting failed!error code:%d\r\n", re);
       // DAQmx Start Code
       re = DAQmxStartTask(taskHandle);
       if (re == 0) printf("task start!\r\n");
       else printf("task not started !error code:%d\r\n", re);
       printf("collecting data,Ctrl+C to interrupt\r\n");
       for (int i = 0; i < 1000000; i++) {
              re = DAQmxReadCounterScalarU32(taskHandle, -1, &data[i], NULL);
              if (re != 0) printf("accquire failed!error code:%d\r\n", re);
              if (data[i] > 0)
                     printf("\rCount: %u-%u",i, (unsigned int)data[i]);
              else printf("\rinvalid count input ");
              //fflush(stdout);
       DAQmxStopTask(taskHandle);
       DAQmxClearTask(taskHandle);
       return 0;
And the feedback is as follows:
task created!
clock set!
task start!
invalid count input
Message 1 of 1
(1,369 Views)
