Motion Control and Motor Drives
3Ds max
Hello Everyone,
I'm very new to lab view and I'm just learning. I'm trying to design a human arm in 3D for simulation purposes but before I take any wrong steps, I have a question.
Can I use 3Ds max to model the human arm and then be able to CONTROL it in Labview? I desperately need help for this? Is it possible? Should I continue with 3Ds max. I don't want to waste time on modelling the arm and then later find out that it cannot be controlled but only viewed in Lab View.
Are there any examples I can refer to?
Thank you so much for your help.
(3,228 Views)
there is no available support for 3Ds Max model in LabVIEW. I do not have experience on it but if 3ds max has activex interface, you can use those objects in the LabVIEW activex containers.
Here you find information about:
http://www.ni.com/support/esa/labview/program/activex/
http://www.ni.com/white-paper/2983/en/
I hope this is helpfull.
Regards
(3,206 Views)
