Motion Control and Motor Drives
Connecting MID-7604/7602 to computer vhdci issue
I am trying to connect the MID-7604/7602 motor drive to my computer in order to use LabVIEW in my stepper motor control. The driver comes with a vhdci 68 pin port for motion i/o control. My issue is that I understand that the driver is supposed to connect directly to my computer but the computer does not have this port to use a vhdci to vhdci cable for connection. Is there an adapter or cable of some sort I should be using instead to establish connection or should I be using a third party (a second driver etc.) to connect the driver to and then this would connect to the computer?
Thank you for the help!
(2,498 Views)
Were you able to find a solution for this issue? We are facing the same problem.
(1,595 Views)
