Motion Control and Motor Drives
Using EPOS with a USB port
I am attempting to control a motor using using the EPOS2 board connected via the USB port.
I have been able to control the motor using the Maxon supplied EPOS Studio application.
I wish to contol this using LabView and have downloaded the library driver. I have installed this in the instrument library and have the VI's available in my pallet.
I have not been able to control the motor using the example VI's
My question is this: Can I control the motor directly using the USB portor do I have to use a CAN interface of some sort?
Hardware:
Dell lattitude laptop
Maxon EPOS2 24/2  positioning controller board connected to laptop via a USB cable.
Kevin
(9,405 Views)
Read this discussion and let us know if it solves your problem.
(9,397 Views)
I updated the driver and I am using the example VI "Example_Demo.vi"
It appears to be communicating with the motor, however I am unable to cause any motor movement.
I suspect this is due to a setting or parameter I have incorrectly set.
I am using a EPOS2 24/2 controller
For my Device settings I have the following
Device Name: EPOS2
Protocol Stack Name: MAXON SERIAL V2
Interface Name: USB
Port Name: USB0
Baudrate: 1000000
Timeout: 500 ms
Here is a screenshot of my settings.
Any suggestions on what I may be doing incorrectly would be appreciated.
Kevin
(9,377 Views)
Hello Kevin,
I have also used EPOS2 with USB with labview. I thing the problem you might have is that your driver for EPOS2 may not be correctly installed. Or you may not have configured your motor with EPOS2 studio.
1) Check with device manager your EPOS2 drivers and update them if not properly installed.
2) Then try configuring your drive with EPOSstudio and try using the tools and do position control.
3) If it is working over there, it should definitely work over labview.
P.S . Dont worry about the example. Even I got trouble from that. Try making your own program :- InitialiseDlg, EnableAXis and in While loop do your axis control.. That should do your job. It works fine with windows dll.
I am trying to develop a custom usb driver for using EPOS with a USB port on my SBRIO (quite a challenging one) and so far it is getting detected but not proceeding further. Please help if you can and hope this helps you. Have a nice day.
Suraj.
(9,171 Views)
