04-01-2020 05:03 AM
I've a cRIO -9064 with AKD Kollmorgen by EtherCAT. I need to know how to send a speed setpoint with my cRIO (as master). Have you some examples of control by labVIEW ? Probably in the first time I must configure my AKD Kollmorgen as slave and my cRIO as master and how can I communicate with my motor by EtherCAT ? Thank
04-23-2020 01:32 AM
Have you tried reading this document? This is pretty comprehensive.
Getting Started with AKD EtherCAT Drives and the LabVIEW NI SoftMotion Module
http://www.ni.com/pdf/manuals/375592f.pdf
Also some great youtube videos here:
04-23-2020 03:07 AM - edited 04-23-2020 03:10 AM
You say :
"Getting Started with AKD EtherCAT Drives and the LabVIEW NI SoftMotion Module"
But I communicate with AKD only by EtherCAT and not with NI SoftMotion, either it does not exist anymore since LabVIEW 2019. I read the documentation, it is long and not easy to translate with the code. If you have an example with LabVIEW how to communicate directely by EtherCAT with AKD Kollomorgen It'll be better. Thanks for your helps.
12-01-2023 08:40 PM - edited 12-01-2023 08:49 PM
PDF document is no longer on NI pages (likely due to discontinued support for NI SoftMotion)
You can now find this document here: https://studylib.net/doc/10930521/getting-started-with-akd-ethercat-drives-and-the-%C2%AE
