Motion Control and Motor Drives
error in using softmotion
when i want to add the solidworks to the project i got this error in the picture ?
thanks
(5,465 Views)
Hi Eng. Tareq,
Just to ask,
  1. What is the versions of your LabVIEW, Softmotion, and Solidworks that you are using?
  2. What is the operating system that you are running on?
  3. Is the LabVIEW version that you are using is the first LabVIEW you have install? (i.e. you did not install the newer versions of LabVIEW before)
Warmest regards,
Lennard.C
Learning new things everyday...
(5,445 Views)
  1. What is the versions of your LabVIEW, Softmotion, and Solidworks that you are using?       LAbview 2010
  2. What is the operating system that you are running on?  7 64bit
  3. Is the LabVIEW version that you are using is the first LabVIEW you have install? (i.e. you did not install the newer versions of LabVIEW before)    2010
(5,438 Views)
Hi Eng. Tareq,
  1. What is the Softmortion version that you are using?
  2. What is the Solidworks version that you are using?
I noticed you have managed to connect to solid works (http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/turn-to-active-mode/m-p/2538850#M12847). So did you receive the error again when you want to add the solidworks to the project?
Thank you
Warmest regards,
Lennard.C
(5,431 Views)
after i did what this friend suggest me it is ok now
(5,429 Views)
