05-20-2010 08:20 PM
Hi, I am currently using the 6024E and Amux-64t to measure a known voltage through LabVIEW. However when I display the readings in a waveform graph, I see a sharp sinusoidal waveform with peaks of the known voltage. My question would be that do I have to set the sample rate and sample size to a certain ratio for me to receive a flat constant voltage of what is expected?
I am using the Legacy Traditional DAQ driver.
Thanks in advance.
05-20-2010 08:58 PM
