10-24-2023 03:27 PM
Planning to install a PXIe-6738 in to a PXIe-8861 Linux RT chassis and confused on the ground connections. The intent is to use the board to drive analog inputs on a controller which also has high current (up to 20A) drivers. Can the ground of the PXIe-6738 board be referenced to the analog ground of my controller or is it internally grounded through the PXI chassis?
10-24-2023 10:50 PM
Use the dedicated AGND pins of the 6738 to connect with the external equipment.
Can you share more info on your high current driver controller?
