Multifunction DAQ
Analog Output has to follow analog input
I am trying to achieve the following: I have a TTL signal which goes on and off with (not exactly known) intervals of several milliseconds. Now I would like to have an analog output which does exactly the same, but with a voltage that I can set. I came up with the following, but it seems it is not fast enough. The rising edge is detected, but not always the falling edge is detected (it happens for example 5 ms after the rising edge). Is there any way to speed up this process?
Thank you very much.
(3,144 Views)
A hardware solution would be an analog switch like the LTC221 or a buffer with enable
Greetings from Germany
Henrik
LV since v3.1
(3,132 Views)
Thanks, but I would like to do it with the DAQ card I currently have (PCI-6229), it is not the only thing I want to synchronize to the input signal and I also later might need to be flexible in timing, voltage etc.
(3,121 Views)
you can use a device which can do digital change detection. Some examples:
Synchronize Multiple Devices with AI Start Trigger and Change Detection using DAQmx:
https://forums.ni.com/t5/NI-DAQmx-Examples/Synchronize-Multiple-Devices-with-AI-Start-Trigger-and-Ch...
Digital Change Detection in NI-DAQmx:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAn9SAG&l=en-US
--> see 3. DAQmx Hardware that Supports Change Detection  (please check if a TTL signal is needed or if only a digital signal is ok)
DAQmx Read Digital Channel- Change Detection Clock:
https://forums.ni.com/t5/NI-DAQmx-Examples/DAQmx-Read-Digital-Channel-Change-Detection-Clock/td-p/35...
I hope this helps.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(3,097 Views)
