04-18-2016 03:29 PM - last edited on 11-21-2024 09:38 AM by Content Cleaner
Reposted sa per Charlies' recommendation
Acquisted Data delay
04-15-2016 05:17 PM
Hi All
I am using the NI USB 6281 to generate and aquist underwater acoustic signal. I sent and received 500 pings and attached spectrogram is from revceived data. Since my Hydrophone is 1m apart from my Transducer, I expect to see the first DARK RED points coming at about 0.67ms ( time =Distance/speed =1/1500) and all of them should be almost on the same line but they dont as you can see in attached file. Any hint will help.
Hi Fedor.Ng,
With the image you've provided, the only thing I can think of would be that your data acquisition or signal generation may not be happening at the exact intervals you expect. How are you generating the pings you are attempting to receive, and how are you receiving them? Are you using Hardware Timing for both of these portions of your code? You would need to be using a DAQmx Timing function call to use hardware timing I believe, and there are several examples included with LabVIEW that show how to use this functionality. You can find said examples in LabVIEW by going to "Help->Find Examples."
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7KdSAK&l=en-US
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
If you are already using hardware timing, have you tried tying the NI USB 6281's input and output together? This should allow you to see if the problem is happening at the DAQ device or if there is some other interference.
I would also recommend posting your question in the Multifunction DAQ board in these forums. This specific forum board is for academic products such as the myDAQ or myRIO, while your device is generally better classified as a Multifunction DAQ.
http://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
Charlie J.
Applications Engineering
04-19-2016 09:10 AM - last edited on 11-21-2024 09:38 AM by Content Cleaner
Hi Fedor,
as Charlie mentioned, if you don't use hardware timing you cannot be sure whether your signals are synchronized. As a result the time/distance data will be rather unreliable and dependent on the speed of your computer, tasks running in the background etc. Those are only assumptions but since I haven't seen your code I cannot say much more.
LabVIEW for sure gives more flexibility, but you can use hardware timing and synchronization options in SignalExpress (at least to some extent). Please refer to the help topics to get more information.
