Multifunction DAQ
Best device to measure two ~.5mV signals at 1kHz
I have found some cards, but not sure about their utility for my needs. I have little experience with DAQs. I need to measure simultaneously two small signals (1~.3mV) at a sample rate of 1kHz. Most cards have 200mV setups, but it is unclear to me if they are sensible enough... there are some specs like accuracy and sensibility... but not sure what to look for my needs. Also, if I can use simultaneously two channels.
(2,763 Views)
Hey,
If you need real simultanous measurements you will need to use S-Series cards, or some special C-Serial modules with USB Carrier or DSA Cards.
You see there are lots of possibilities.
I would recommend you to contact your local NI office and talk to an technical sales representive which can give you the best advice to your needs.
Christian
(2,740 Views)
