Multifunction DAQ
Blue screen and 9163
António,
-50804 or 50804 are still the same it is just the syntax error given by the error message. Firmware update is here and after apply the8.9 May version patch. Then, I invite you to see here particulary the step by step solution of this thread for updating the firmware version of your ENET9163.
Steve M.
Message 11 of 14
(978 Views)
It happen again. The DAQ 8.9.0f4 only delay the problem.
Message 12 of 14
(822 Views)
Hi acardoso-
I'm sorry to hear that you are still seeing the issue.
In the couple of years since your last post we have worked to significantly improve resiliency in cases like this where network connections are lost.  I can not say that it will definitely fix your problem, but I would recommend that you update your NI-DAQmx driver to the latest version (NI-DAQmx 9.4, as of Aug 2011).
I realize you have been advised to upgrade before and it has not completely fixed your issue, so please do not lose confidence in our abilities to offer suggestions.  NI-DAQmx 9.4 offers several specific bugfixes that we discovered and fixed in the last 6-12 months, so it is certainly worth a try.  One other thing to note: before upgrading your NI-DAQmx version, please confirm that your version of LabVIEW or other programming environment is still supported.  You can find that information in the readme.
Hopefully this helps-
Tom W
Message 13 of 14
(810 Views)
At the moment, I performed the update and everything I was asked. After that I started to have time to go there and stop the application.
This condition only happens when the Enet 9163 enters on error and the keeps hammering the module
Usually, I have to reset the enet at MAX, only once I had to power down, to retrieve normal operation.
I can not update for 9.4 because I have LV8.2 running there. I have to upgrade first.
Message 14 of 14
(800 Views)
