Multifunction DAQ
C reference help cdaqmx.chm missing from Start menu in NI-DAQmx 8.9 install
Prior to NI-DAQmx 8.9 there was an option from the Start menu to open the C reference
Start-> All Programs->National Instruments->NI-DAQ->NI-DAQmx C Reference Help
to bring up  the help
C:\Program Files\National Instruments\NI-DAQ\Docs\cdaqmx.chm
It's mentioned  on this page as well: http://zone.ni.com/devzone/cda/tut/p/id/5489#toc2
In two 8.9 installs I did it is missing and I don't recall seeing an option to include it.
Of course I can get to the file via the full path and have created a desktop link to do this, but I was wondering if this was an intentional change and if we can get the Start menu link back in the next release?
Thanks!
Sherryl Radbil
Data Acquisition Engineer
The MathWorks
(4,872 Views)
Hi Sherryl,
The C Reference Help file should still accessible through the start menu, although the location has moved slightly as of DAQmx 8.9. I would try looking here:
Start -> All Programs -> National Instruments -> NI-DAQ -> Text-Based Code Support -> NI-DAQmx C Reference Help
You should be able to get to the help as I have done in the above screenshot, but please let us know if this is not the case.
-John
John Passiak
(4,858 Views)
