Multifunction DAQ
CI.Min in *.ini configuration file of NI PCI 6229
Hi, I have created the configuration file in *.ini format using the export option in Measurement and Automation Explorer. In counter section the value of CI.Min =9.9999999999999995E-007 and Measurement type is Semi Period. Can you give the explanation on this? Thanking You Nagaraja B
Message 1 of 1
(3,071 Views)
