03-18-2008 02:01 PM
03-19-2008 04:31 PM
I looked into the differences of the two devices. You are correct, the pin out of the devices are the same. The only difference I can see with a couple initial searches is that the devices have two different maximum sample rates. The AT-MIO-64E-3 (6061E) form factor has a maximum sample rate of 1E500 KS/s and the PCI 6071E has 1.25 MS/s. If the software is the same, I do not see any issue with swapping the cards. Worse case you might have to adjust the sample rate, however it might be set to the the same rate in each system.
