Multifunction DAQ
Change Physical Channel Name of Global Channel
My current project is a test equipment with five indentical fixtures. Each of them uses a NI PCIe-6341.
With MAX, I have just defined the scales and global channels for the first of them. Instead of repeating the task for the other fixtures by hand, I'm now trying to copy/edit them programmatically with LV.
No problem for the scales.
Almost the same for the global channels but with a exception. It is easy to copy the channels and also to change the names of the scales they use. Unfortunately, I wasn't able to change the Physical Channel (eg from Dev1/ai0 to Dev2/aio).
This property generates the error -200452 (Specified property is not supported by the device or is not applicable to the task). The DAQ cards are currently simulated. Could this be the reason ? Or is this not the right property ?
Many thanks in advance for any advice.
(2,860 Views)
I'm really surprized by the lack of answer.
Does nobody edit DAQmx scales and global channels programmatically ? NI ?
Is my question not clear enough ?
(2,800 Views)
