11-08-2006 02:39 PM
11-09-2006 01:54 PM
11-10-2006 07:10 AM
Justin,
I have a Cluster of Booleans. Its been sometime so I don't remember exactly WHY I used a Cluster. I think it was because I wanted to give each Boolean a different property. I use the cluster as a display panel on my test vi. I read in 960 chs and display whether or not they are on. Part of my requirement is to save the display at the time of the test. I don't know why because I save the actual voltages in each ch. Maybe I could recreate the display after its be saved based on the volts in each ch. Its a long story but I went back and forth with National ( different App Engrs) on saving the data. First as TDM files. That didn't seem to work. Then I tried saving it using the save the data to a spreadsheet vi. That had limitations. With each iteration I lose time because its a total re-vamping of my saving vi. I'm real close. I'll try your suggestion.
Just to let you know. There is more to saving the data then just the 960 ch's. There are things to save like PASS or FAIL, Operator Name, +/- limits, etc.
Clint E.
