Multifunction DAQ
Creating a task with NI9472 and counter from cDAQ9178 for PWM
For a project I need to create a DAQmx task for PWM in my project library.
I have the NI 9472 Digital Out module with no counters, and a NI compactDAQ 9178 with 4 counters.
How can I configure the task so that I can use the counter from the cDAQ to output PWM from the digital out module?
Thank you and as always, kudos will be given! Robot Very Happy
(5,454 Views)
Giant,
I'm guessing you are programming this in LabVIEW? Either way, you really shouldn't have much trouble with this, the example I point out are in LabVIEW. You will natively be able to access the 9178 counters from your 9472 module. I simulated something similar to what you have:
From there, you just need to specify the Counter and Output Terminal in your program. There is an example in LabVIEW 2012 in the Example Finder called "Counter - Continuous Output" that I am using.
This will allow you to route your signal to the line you want. Now as for changing the duty cycle of the PWM, NI has a good white paper on the topic.
Pulse Width Modulation (PWM) Using NI-DAQmx and LabVIEW
http://www.ni.com/white-paper/2991/en/
Hope this helps.
Aaron W.
CLA, CTA and CPI
(5,444 Views)
Aaron_W thank you for your awesome reply!
(5,439 Views)
I work with the NI 9472 Digital Out module with 4 counters assembled in a NI compactDAQ 9178.
I see in the default allocation of the module that:
- CTR 0 OUT is working on PFI3
- CTR 1 OUT is working on PFI7
- CTR 2 OUT is working on PFI1
- CTR 3 OUT is working on PFI5
Is it possible to modify this allocation with the following settings:
- CTR 0 OUT to work on PFI0
- CTR 1 OUT to work on PFI1
- CTR 2 OUT to work on PFI2
- CTR 3 OUT to work on PFI3 ?
If yes, what tool do I have to use to perform this operation?
Xavier
(3,528 Views)
Hello Xavier,
I don't think that the cDAQ is flexible enough to allow you to choose to which output a counter is connected to. I'm not 100% sure how this work, but the backplane of the cDAQ would need an expensive switching matrix to allow this.
(3,523 Views)
Hi Xavrocg,
As previously mentioned it is possible based on the device to route to different locations on the device. Some if not all of this routing is possible. I have attached a couple of articles outlining the method you can do this:
Internally Routing Counter Signals:
http://digital.ni.com/public.nsf/allkb/8A85E97855EDADC98625730C00065F58
How Can I Know What internal routes are available on my device:
http://digital.ni.com/public.nsf/websearch/E539D226A643C1CE8625715E007C23C8
Kind Regards,
Matt Fergusson
(3,515 Views)
Iqnore my previous answer, I was obviously wrong. Sorry about that.
(3,512 Views)
