Multifunction DAQ
Deployment to a different machine using NI DAQ MX
Hi
I am currently trying to deploy a windows application for MicroSoft Visual Studio 2010 on an XP machine to a Windows 7 test machine i am getting the following error:
  Problem Event Name: CLR20r3
  Problem Signature 01: analogdatafileprocessor.exe
  Problem Signature 02: 1.0.4825.31049
  Problem Signature 03: 51474b93
  Problem Signature 04: AnalogDataFileProcessor
  Problem Signature 05: 1.0.4825.31049
  Problem Signature 06: 51474b93
  Problem Signature 07: d
  Problem Signature 08: 12
  Problem Signature 09: System.IO.FileNotFoundException
  OS Version: 6.1.7601.2.1.0.256.48
  Locale ID: 2057
  Additional Information 1: 2a49
  Additional Information 2: 2a49e006c888f45db5496d2a223605c3
  Additional Information 3: b710
  Additional Information 4: b710a137618e67ff3fdc12dbc8b86878
This error is occuring for both my project and the example project (Path Below) and only occurs when the NI parts of the program have been added. I can only assume that I am missing a driver or an incorrect driver has been installed.
C:\Documents and Settings\All Users\Documents\National Instruments\MStudioVS2010\DotNET\Examples\DAQmxWithUI\AnalogDataFileProcessor\cs
I am using the following references
NationalInstruments.Common   V4.0.30319
NationalInstruments.DAQMX     V4.0.30319
NationalInstruments.UI               V4.0.30319
NationalInstruments.UI.WindowsForms  V4.0.30319
Also on the Aug 2011 disk I have the following drivers installed
In application development support of NI-DAQmx 9.3.5:
LabWindows/CVI Support
.net framework 4.0 languages support
Ansi C Support
Can anyone suggest how I can solve this problem. Thank you in advance
(2,886 Views)
Hi Tom
Have you made any progress with this?
Is the Windows 7 machine running a 64 bit OS, is it running 64 bit LabVIEW?
Which version of DAQmx do you have installed on the development PC?
Which version of DAQmx do you have installed on the deployment PC?
Kind Regards
Chris | Applications Engineer NIUK
(2,824 Views)
