Multifunction DAQ
Displaying 1000 S/s data without affecting speed of display
I want to collect the data at 1000 samples/sec for at least 6 minutes using DAQ assistant and writing the data to a .lvm file or .txt file which I am able to do correctly. Then later on using another code on LabVIEW I am reading the 6 minutes of data to process it further and play it on front panel while collecting the real-time data. I am storing the 6 minutes read data and the current data to .lvm file or .txt file. When I am trying to do this the display of the data is becoming really slow. But the data is correctly written to the file. How to avoid this problem. I know that if I compromise on sampling rate I can get over this problem. But is there any way to get over the problem without changing the sampling rate.
Thank you in advance.
(2,639 Views)
How quickly does your graphics card and monitor update?  You are experiencing buffering on your screen.  Also, if your code reads back and builds the array on-the-fly, then it will take longer as each data point added to the array requires a new memory location to be established.  Try to allocate the necessary memory size prior to reading the file (1000 samples/second *  6 minutes * 60 seconds/minute) then using a loop, place the data in the proper spot in that array.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,597 Views)
Thank you for your reply.
How would I find out the speed of the graphics or the monitor speed?
In my program I am sequentially doing the following. In first sequence loading the data from .lvm file and copying that to an initialized array of the size of the data to be transferred. Then I using the initialized array for plotting the points. But after that only the display is being slow.
(2,589 Views)
Previously I was displaying 10000 data points on the graph and collecting the data at 1000 samples/sec. But when I displayed 6000 data points on the graph while collecting the data at 1000 samples/sec the speed did not get affected for longer time but not 6 minutes. Does any one have any idea on how to improve it further. I can not go less than 6000 data points on the graph.
Thanks in advance.
(2,566 Views)
How about attaching your vi?
Greetings from Germany
Henrik
LV since v3.1
(2,548 Views)
My program reads the already recorded data at 1000 samples/sec and reads it. Then it displays the already recorded data with realtime data and stores it in a .lvm file. My vi works fine for 500 Sample/sec but doesn't for 1000 Samples/sec.
(2,542 Views)
