Multifunction DAQ
Doubt regarding data acquisition card connector?
We are purchased data acquisition card from NI,Form that acquiring the data we need Dual  68 pin male connector,
For acquiring data Is there any other connector with lower prices,If any connector is there inform me.
Thank you.
(2,748 Views)
hey nstl,
what exact part are you reffering to? is it the same connector as on the board or you want to create your own cable? I believe those connectors you can buy from theirs original manufacturers. Just search for 68 pin VHDCI connector or 68 pin D sub connector.
if you are reffering to connector block - I mean that you need connector block and cable, then you of course need something to connect your signals to DAQ board. If you are looking for ready solution, then I believe yout sales representative would advise you the best. If you are looking for the cheapest solution, you can just buy the connectors and create connector block yourself. But this option requires some more work from your side.
regards,
stefo
(2,729 Views)
