Multifunction DAQ
Down loaded trial Daztlab13 but can not get it to find my MCC USB-1208FS.
I downloaded the trial Dasylab 13 but I can not get Dasylab to use my mcc USB-1208 unit it always loads the sound Card and i do not see any option to change it.
(3,527 Views)
Hi wolfg,
Unfortunately since you aren’t using DASYLab in conjunction with any NI hardware, there isn’t a ton of insight I can give you in terms of your inquiry. That being said, I would recommend reaching out to MMC directly in order to further address the issue. The links below will take you to those support avenues.
Tech Support for Measurement Computing DAQ Hardware/Software:
http://www.mccdaq.com/support.aspx
DASYLab Support:
http://www.mccdaq.com/DASYLab-index.aspx
I hope this helps!
Ross S.
Applications Engineering
(3,491 Views)
