Multifunction DAQ
Drivers for PCI 6025E (PCI 8331)
Dear All,
I am trying to install drivers for an instrument which has PCI 8331 in the connected computer.
I have tried NI-DAQmx or NI-DAQ, but Measurement & Automation Explorer still can't find the divice.
Also when I open the software for the instrument, it shows PCI 6025E is not found.
I would appricate if you could give me any suggestion. Thanks!
(4,971 Views)
Are you sure it is not a PXI-6025E you are trying to connect to?  If not, I do not see what the MXI-4 connection has to do with anything.
Is the PXI chassis turned on and connecter BEFORE you turn on the computer?  That is a requirement for PXI.  Since it is an extension of PCI, the discovery is done at bootup.
GCentral
(4,962 Views)
Hello crossrulz,
Thank you for the quick reply.
You are right it is PXI-6025E. However it still can't find the device even if I turned on the instrument first.
Also, Windows shows it found a new PCI hardware and requires installing the driver. But I already installed NI-DAQmx. Is this wrong?
(4,937 Views)
You might want to try installing the PXI Platform Services as well.  I thought it was included with DAQmx, but possibly not.
GCentral
(4,932 Views)
Thanks! I just tried this. I had to install an old version because the OS is XP sp1.
I got something on the device list, but it shows communication is not available, as shown in the first figure attached.
According to the doc, I should get something like shown in the second figure.
Do I still miss some other drivers?
(4,906 Views)
