Multifunction DAQ
Erro - 50103 utilizando o NI 9178 + Ni 9219
I'm working with data aquisition using the cDAQ NI 9178 + NI 9219 to measure temperature, pressure, force and deformations.
I made the front panel, but when I use the NI DAQ mx to get my signal values always show the same error: error -50103.
Using this Module (NI 9219) i can get diferent signals but not in my aplicattion, Can you help me?
Attached is the picture of my configurations.
(4,499 Views)
Another Picture.
Regards
Vilson
(4,497 Views)
Search the forums for error 50103 and you'll find the answer.
You can create multiple task that all use the same resource.  You must combine those channels into a single task.
(4,479 Views)
