08-09-2011 01:26 PM
I have a new cDAQ-9188. When running self-test on any of the installed modules I receive error 201388 (network device is not reserved for this host). After clicking Reserve Chassis, and then running self-test this error remains. Also, after clicking Unreserve Chassis, I get the same error.
08-10-2011 08:54 AM
If you reset the chassis using the button on the chassis itself, and then try to reserve it, does the problem persist?
Jon
08-10-2011 03:38 PM
I am not with the system now, so I cannot answer your question.
However, I was able to overcome the problem by launching the Reserve Chassis method from a different spot with MAX. I was having trouble with Reserve Chassis when I had the NI cDAQ-9188 .... highlighted in the tree view and using the Reserve Chassis button in the right pane. Reserve Chassis worked when I highlighted Network Devices in the tree view and chose Reserve Chassis by right-clicking the NI cDAQ 9188 in the right pane.
Thanks for your response.
