05-29-2009 07:09 PM - edited 05-29-2009 07:13 PM
I am trying to find out how much delay there is between samplings of two AI channels in a USB 6251 (Mass Term) used in conjunction with a SCB-68 connector block (Labview 8.5, Windows XP). I realize that there is only one ADC and simultaneous acquisition is not available. The specs are listed as follows:
Sampling Rate:
Maximum: 1.25 MS/s single channel; 1.00 MS/s multi-channel (aggregate)
Minimum: No minimum
Timing accuracy: 50 ppm of sample rate
Timing resolution: 50 ns
Does any one know of a way to figure this out other than through experimentation?
05-29-2009 09:05 PM
05-31-2009 03:33 PM
Dear Dennis,
Thanks for your prompt and accurate answer.
