Multifunction DAQ
Hooking Up Multiple Sensors via cDAQ-9174
Hello everyone,
I am what would be called "below a novice" when it comes to experience level for this kind of stuff...
Anyways, I am currently using a cDAQ-9174 with modules 9237, 9411 and 9201 to gather data, however I do not know how to properly wire my sensor to gather data.
The sensors I am using are as follows:
Honeywell Pressure Transducer Model FPB2000, the specs can be found here: https://measurementsensors.honeywell.com/ProductDocuments/Pressure/Model_FP2000_Datasheet.pdf
Futek Torque Sensor Model TRS605, the specs are attatched.  Please note that there is a connector at one end, bare wires at the other.
Dwyer Series VTT Hot-Wire Air Velocity/Temperature Transmitter, the specs can be found here: http://www.dwyer-inst.com/PDF_files/VTT_iom.pdf
So basically my questions are on how to hook these things up to my 9174 to be to start interfacing with lab view and take readings.  Any help would be appreciated as I am completely lost at the moment.  If you need anything else to help let me know.
THANK YOU!
(2,767 Views)
Here are link to the product pages for each of the products that you will be using:
9174 - https://www.ni.com/en-us/shop/model/cdaq-9174.html
9237 - https://www.ni.com/en-us/shop/model/ni-9237.html
9411 - https://www.ni.com/en-us/shop/model/ni-9411.html
9201 - https://www.ni.com/en-us/shop/model/ni-9201.html
If you go the resouces link and then go manuals and then to the user guides. It will show you everything that you need to do.
I hope that this helps.
Perry S.
(2,744 Views)
