Multifunction DAQ
How to assign a DO initial value using the Traditional NI driaver?
Hello everyone,
the question is pretty simple: I am using PCI-6014 DAQ with Traditional (so far) NI driver. I have a device connected to a set of DO's in order to provide for a combination, which selects the mode of operation. As soon as the device is started, and I initialize the DIO, I assign the DO's the initial values. The problem is that it takes some time (approx. 15 ms) to do that, and during this time (between device initialization and initial assignment) the output combination is plain 0, which is highly undesirable due to the device specifics. Is there any way to "hardcode" the DO's initial values, so that as soon as the DAQ is powered up, and the line is declared as DO, it is automatically assigned the pre-defined value?
Thank you in advance,
Mike
(2,736 Views)
Accepted by topic author MikeF_tmt
Have you read the specs? The answer is no.
(2,732 Views)
