07-10-2011 09:46 PM
I have a mks1480A mass flow controller and USB-6353. I need use USB to control mfc. MFC has 15 pins. How to connect USB-6353 to mfc. I don't know which pins of mfc are analog output and which are inputs.
07-13-2011 09:57 AM
Venessa,
I would suggest that you take a look at the documentation for the MKS 1480A. It looks like the product page is located here: http://www.mksinst.com/product/product.aspx?ProductID=61.
I would imagine that the Flow Signal Output (Pin 2) would be the Voltage output of the MFC. It looks like opening and closing the valve is done with pins 3 and 4.
Aaron
