According to the User Guide the power up state is high impedance input with 4700 ohms pull up to +5 V. This device does not appear to have any other options.
You either need to get a different DAQ devices or add external circuitry which will not connect the 6501 to your equipment until it has been driven through a specified High, Low, High, Low sequence which you define and control through another DO line.
Lynn
