Is it possible to syncronise AI and CTR readings? I'm using an M-series device and in LabVIEW I created an AI Task with several inputs and a CTR Channel which used as angular position measurement. It is easy to do a countinous buffered measurement of the analog inputs. But with the same Sample rate I would like to read the counter. DAQmx forces me to use an external clock source for the counter acquisition. Is there a (simple) solution?
