Multifunction DAQ
I can't export my global channels and scales in MAX
When I wan't to export my global channels and scales, I can't select them in the window because they don't appear (see image below). I already did that with a previous release of MAX and it worked fine. What's wrong now ?
Laurent
(3,287 Views)
You seem to have an existing configuration from a previous export. Could you please try to import it (at least a part of it) and let us know if this works ? This operation may switch MAX back to its expected behaviour.
(3,279 Views)
No, it didn't works. I import a old nce file that I have, and then try to export my config. Still the same problem
Laurent
(3,277 Views)
You have the exact issue which myself and at least one other person has already mentioned on the forums. NI has worked towards finding a solution, and they can't find it. As far as I can tell, it's broken and can't be fixed. My 8.5.1 exported fine, but 8.6.1 is broken.
If you have service support active, you need to call NI, and mention this problem.
Richard
(3,255 Views)
