Multifunction DAQ
LabWindows/CVI doesn't detect the NI-DAQmx in the PXI crate
I have a problem with connecting to NI-DAQmx (NI-6221) which is inside a PXI Crate (PXI-1044), with a controller (8108 RT). When I try to connect using LabView or NI-MAX to the device I can do it, I see it and I can generate a simple analog signal on an analog output.
Whereas, when I try to create a task in LabWindows for the NI-DAQmx I can't see any DAQ device. I'm attaching a screenshot. I'm using LabWindows 2015 with SP1, NI-DAQmx 16.1.0 and my os is Win 7 Enterprise.
Any help would be gratly appreciated.
Kind regards,
Piotr Zdunek
Message 1 of 1
(2,403 Views)
