08-15-2023 12:24 PM
I received the Ni-9231 card and right from the start I encountered a problem I can't find the sensor that support TEDS specifically the GRAS 46AE microphone (the NI-9234 card loaded the sensor without problems). I tried to connect the accelerometer PCB and it works without any problems. Do you know what could be the problem?
Thanks for advice
08-15-2023 12:34 PM
Doesn't looks like any difference in support for IEPE & TEDS between 9231 and 9234.
How did you connect and test?
08-15-2023 12:41 PM - edited 08-15-2023 12:47 PM
I bought a BNC adapter (female end) for the card, so I connected the accelerometer directly to this adapter. I connected the microphone using a BNC cable ( male-male), I tried 2 cables of 0,5m and 1 of 4m length.
For testing I run NI-MAX and try to find TEDS, microphone itself works if I run it as IPEE sensor.
08-15-2023 03:58 PM
Wait, at first you said the Mic is not detected, now you say it works. Could you please summarize your observations, status and problem?
